주요 콘텐츠로 건너뛰기
Asus Q550LF-BBI7T07 Disc Drive Replacement
필요한 것
  1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: 1 단계, 이미지 1/2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Disc Drive Replacement: 2 단계, 이미지 1/2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Disc Drive Replacement: 3 단계, 이미지 1/2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Disc Drive Replacement: 4 단계, 이미지 1/2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 4 단계, 이미지 2/2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: 5 단계, 이미지 1/2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: 5 단계, 이미지 2/2
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Disc Drive Replacement: 6 단계, 이미지 1/2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 6 단계, 이미지 2/2
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: 7 단계, 이미지 1/2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: 7 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Disc Drive Replacement: 8 단계, 이미지 1/1
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Disc Drive Replacement: 9 단계, 이미지 1/2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 9 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Disc Drive Replacement: 10 단계, 이미지 1/2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 10 단계, 이미지 2/2
    • Slowly slide out the disc drive, keeping it level, to remove it.
결론
Chance Woudenberg
회원 가입일: 10/02/18
694 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 443
