주요 콘텐츠로 건너뛰기
Asus Q551L Repair Motherboard Replacement
필요한 것
  1. Asus Q551L Repair Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Asus Q551L Repair Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 1개 Asus Q551L Repair Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Repair Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Asus Q551L Repair Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): 5 단계, 이미지 3개 중 1개 Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): 5 단계, 이미지 3개 중 2개 Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): 5 단계, 이미지 3개 중 3개
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
  6. Asus Q551L Repair Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 Asus Q551L Repair Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 Asus Q551L Repair Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Remove the fan by unscrewing the nine screws shown in the images.
    • The four colored wire and the black cable need to be pulled out gently.
    • There will be wires around the fan. Make sure they are not stuck to it.
    • You want to keep the fan if it still in good conditions.
  7. Asus Q551L Repair Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Asus Q551L Repair Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
  8. Asus Q551L Repair Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Asus Q551L Repair Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Asus Q551L Repair Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect any cables that hold the motherboard.
    • Open up the white adjustable latch first to pull out the tapes.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Baker
회원 가입일: 01/17/18
300 평판
안내서 1개를 작성함
1가이드 댓글
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 2,658
