주요 콘텐츠로 건너뛰기
Asus R510CA-OB01 Hard Drive Replacement
필요한 것
  1. Asus R510CA-OB01 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computer so that it is upside down. Position the computer with the front towards you.
  2. Asus R510CA-OB01 Hard Drive Replacement: 2 단계, 이미지 1/2 Asus R510CA-OB01 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Loosen the two 12 mm screws on the bottom panel of your device using a Phillips size 0 bit.
  3. Asus R510CA-OB01 Hard Drive Replacement: 3 단계, 이미지 1/3 Asus R510CA-OB01 Hard Drive Replacement: 3 단계, 이미지 2/3 Asus R510CA-OB01 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  4. Asus R510CA-OB01 Hard Drive Replacement: 4 단계, 이미지 1/3 Asus R510CA-OB01 Hard Drive Replacement: 4 단계, 이미지 2/3 Asus R510CA-OB01 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Loosen the three 5 mm screws holding down the hard drive using a Phillips #00 bit.
  5. Asus R510CA-OB01 Hard Drive Replacement: 5 단계, 이미지 1/2 Asus R510CA-OB01 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Slide the casing (hard drive bay) for the hard drive to the left.
    • Lift it to remove it from the device.
결론
Blanche Pinto
회원 가입일: 09/28/17
437 평판
안내서 4개 작성하였습니다
USF Tampa, Team S3-G4, Nance Fall 2017 USF Tampa, Team S3-G4, Nance Fall 2017 회원
USFT-NANCE-F17S3G4
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 616
