주요 콘텐츠로 건너뛰기
Asus R510CA-OB01 Keyboard and Mousepad Replacement
필요한 것
  1. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: 1 단계, 이미지 1/3 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: 1 단계, 이미지 2/3 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the two switches that lock the battery.
    • Then, push the right switch outward to unlock it.
  2. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 2 단계, 이미지 1/2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 2 단계, 이미지 2/2
    • Push the left switch outward and push the battery upward at the same time.
  3. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 3 단계, 이미지 1/1
    • Use a Li-ion battery as a replacement for your battery.
  4. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Keyboard and Mousepad: 4 단계, 이미지 1/1
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  5. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 5 단계, 이미지 1/1
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  6. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 6 단계, 이미지 1/2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 6 단계, 이미지 2/2
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  7. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 7 단계, 이미지 1/3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 7 단계, 이미지 2/3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 7 단계, 이미지 3/3
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  8. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 8 단계, 이미지 1/2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 8 단계, 이미지 2/2
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  9. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 9 단계, 이미지 1/2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 9 단계, 이미지 2/2
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  10. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 10 단계, 이미지 1/2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 10 단계, 이미지 2/2
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  11. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 11 단계, 이미지 1/3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 11 단계, 이미지 2/3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 11 단계, 이미지 3/3
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  12. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 12 단계, 이미지 1/2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 12 단계, 이미지 2/2
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
결론
Blanche Pinto
회원 가입일: 09/28/17
437 평판
안내서 4개 작성하였습니다
USF Tampa, Team S3-G4, Nance Fall 2017 USF Tampa, Team S3-G4, Nance Fall 2017 회원
USFT-NANCE-F17S3G4
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 810
