주요 콘텐츠로 건너뛰기
Asus R510CA-OB01 Motherboard Replacement
필요한 것
  1. Asus R510CA-OB01 Motherboard Replacement, Keyboard and Mousepad: 1 단계, 이미지 1/1
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  2. Asus R510CA-OB01 Motherboard Replacement: 2 단계, 이미지 1/1
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  3. Asus R510CA-OB01 Motherboard Replacement: 3 단계, 이미지 1/2 Asus R510CA-OB01 Motherboard Replacement: 3 단계, 이미지 2/2
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  4. Asus R510CA-OB01 Motherboard Replacement: 4 단계, 이미지 1/3 Asus R510CA-OB01 Motherboard Replacement: 4 단계, 이미지 2/3 Asus R510CA-OB01 Motherboard Replacement: 4 단계, 이미지 3/3
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  5. Asus R510CA-OB01 Motherboard Replacement: 5 단계, 이미지 1/2 Asus R510CA-OB01 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  6. Asus R510CA-OB01 Motherboard Replacement: 6 단계, 이미지 1/2 Asus R510CA-OB01 Motherboard Replacement: 6 단계, 이미지 2/2
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  7. Asus R510CA-OB01 Motherboard Replacement: 7 단계, 이미지 1/2 Asus R510CA-OB01 Motherboard Replacement: 7 단계, 이미지 2/2
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  8. Asus R510CA-OB01 Motherboard Replacement: 8 단계, 이미지 1/3 Asus R510CA-OB01 Motherboard Replacement: 8 단계, 이미지 2/3 Asus R510CA-OB01 Motherboard Replacement: 8 단계, 이미지 3/3
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  9. Asus R510CA-OB01 Motherboard Replacement: 9 단계, 이미지 1/2 Asus R510CA-OB01 Motherboard Replacement: 9 단계, 이미지 2/2
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
  10. Asus R510CA-OB01 Motherboard Replacement, Optical Drive: 10 단계, 이미지 1/2 Asus R510CA-OB01 Motherboard Replacement, Optical Drive: 10 단계, 이미지 2/2
    • Remove the 4.5mm silver screw in the top right corner using a Phillips #0 bit.
    • Remove the three 2mm silver screws using a Phillips #000 bit.
    • Remove the 5mm screw using a Phillips #1 bit that is holding the optical drive in place.
    • With your hands, gently slide the optical drive out of the laptop.
  11. Asus R510CA-OB01 Motherboard Replacement, Motherboard: 11 단계, 이미지 1/1
    • Remove the seven 5mm screws that are holding both the fan and motherboard in place using a Phillips #1 bit.
  12. Asus R510CA-OB01 Motherboard Replacement: 12 단계, 이미지 1/3 Asus R510CA-OB01 Motherboard Replacement: 12 단계, 이미지 2/3 Asus R510CA-OB01 Motherboard Replacement: 12 단계, 이미지 3/3
    • Disconnect the cables from the motherboard by sliding the cable out of place.
    • Disconnect the cables connecting the fan to the motherboard and laptop by pulling the cable out of place.
  13. Asus R510CA-OB01 Motherboard Replacement: 13 단계, 이미지 1/2 Asus R510CA-OB01 Motherboard Replacement: 13 단계, 이미지 2/2
    • Lift the motherboard on the right side so that it is lifted slightly above the hard drive.
    • Slide the motherboard and fan to the right. Both components should be free from the device.
    • Once the fan and motherboard are free from the device, flip them over and remove the cable connecting both components.
  14. Asus R510CA-OB01 Motherboard Replacement: 14 단계, 이미지 1/2 Asus R510CA-OB01 Motherboard Replacement: 14 단계, 이미지 2/2
    • Remove the four 5mm screws connecting the fan and motherboard using a Phillips #1 bit.
    • Once the screws have been removed, the fan and motherboard should come apart.
  15. Asus R510CA-OB01 Motherboard Replacement: 15 단계, 이미지 1/1
    • The motherboard should now be free from the device .
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mame
회원 가입일: 03/25/19
13 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G2, Henning Spring 2019 IUPUI, Team S1-G2, Henning Spring 2019 회원
IUPUI-HENNING-S19S1G2
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 618
