주요 콘텐츠로 건너뛰기
Asus R510LA-RS71 Hard Drive Replacement
필요한 것
  1. Asus R510LA-RS71 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Asus R510LA-RS71 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Remove the bottom left and right 12.7mm screws using a JIS 00 screwdriver.
  2. Asus R510LA-RS71 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide back and remove the protective plating on the back of the laptop.
  3. Asus R510LA-RS71 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Again with the JIS 00, unscrew the three 5.7mm screws holding the hard drive in place. These can be found on small brackets on the four corners of the drive.
  4. Asus R510LA-RS71 Hard Drive Replacement: 4 단계, 이미지 1/3 Asus R510LA-RS71 Hard Drive Replacement: 4 단계, 이미지 2/3 Asus R510LA-RS71 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Slide the hard drive to the left, then remove it by lifting it from the compartment it is resting in.
결론
Spencer Whitworth
회원 가입일: 02/15/18
186 평판
안내서 1개 작성함
USF Tampa, Team S1-G6, Leahy Spring 2018 USF Tampa, Team S1-G6, Leahy Spring 2018 회원
USFT-LEAHY-S18S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 471
