주요 콘텐츠로 건너뛰기
Asus R510LA-RS71 Screen Replacement
필요한 것
  1. Asus R510LA-RS71 Screen Replacement, Screen: 1 단계, 이미지 1/3 Asus R510LA-RS71 Screen Replacement, Screen: 1 단계, 이미지 2/3 Asus R510LA-RS71 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Using a metal spudger, pick out the stoppers located on the bottom left/right corners of the screen, revealing the screws underneath them.
    • Unscrew the two 4.25mm screws with the JIS 00 screwdriver.
  2. Asus R510LA-RS71 Screen Replacement: 2 단계, 이미지 1/3 Asus R510LA-RS71 Screen Replacement: 2 단계, 이미지 2/3 Asus R510LA-RS71 Screen Replacement: 2 단계, 이미지 3/3
    • Using the metal spudger, pry off the edges of the screen's frame from the outside.
  3. Asus R510LA-RS71 Screen Replacement: 3 단계, 이미지 1/3 Asus R510LA-RS71 Screen Replacement: 3 단계, 이미지 2/3 Asus R510LA-RS71 Screen Replacement: 3 단계, 이미지 3/3
    • There should be four silver brackets holding the screen in place underneath. Unscrew the center 3.35mm screws in each bracket as shown with the JIS 00 screwdriver.
  4. Asus R510LA-RS71 Screen Replacement: 4 단계, 이미지 1/3 Asus R510LA-RS71 Screen Replacement: 4 단계, 이미지 2/3 Asus R510LA-RS71 Screen Replacement: 4 단계, 이미지 3/3
    • Slowly remove the monitor from its recess.
  5. Asus R510LA-RS71 Screen Replacement: 5 단계, 이미지 1/3 Asus R510LA-RS71 Screen Replacement: 5 단계, 이미지 2/3 Asus R510LA-RS71 Screen Replacement: 5 단계, 이미지 3/3
    • Place the monitor face down. Slowly remove the adhesive tape on the back of the monitor, and remove the connector that the tape is holding.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Deliyanis Rosa
회원 가입일: 02/15/18
283 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G6, Leahy Spring 2018 USF Tampa, Team S1-G6, Leahy Spring 2018 회원
USFT-LEAHY-S18S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 481
