주요 콘텐츠로 건너뛰기
Asus R541UA-RB51 Keyboard Replacement
필요한 것
  1. Asus R541UA-RB51 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Asus R541UA-RB51 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Asus R541UA-RB51 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 Keyboard Replacement: 2 단계, 이미지 1/2 Asus R541UA-RB51 Keyboard Replacement: 2 단계, 이미지 2/2
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 Keyboard Replacement: 3 단계, 이미지 1/2 Asus R541UA-RB51 Keyboard Replacement: 3 단계, 이미지 2/2
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Drew Singleton
회원 가입일: 08/31/18
359 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 553
