주요 콘텐츠로 건너뛰기
Asus R541UA-RB51 RAM Replacement
필요한 것
  1. Asus R541UA-RB51 RAM Replacement, Keyboard: 1 단계, 이미지 1/3 Asus R541UA-RB51 RAM Replacement, Keyboard: 1 단계, 이미지 2/3 Asus R541UA-RB51 RAM Replacement, Keyboard: 1 단계, 이미지 3/3
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 RAM Replacement: 2 단계, 이미지 1/2 Asus R541UA-RB51 RAM Replacement: 2 단계, 이미지 2/2
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 RAM Replacement: 3 단계, 이미지 1/2 Asus R541UA-RB51 RAM Replacement: 3 단계, 이미지 2/2
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 RAM Replacement, CD Drive: 4 단계, 이미지 1/1
    • Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
  5. Asus R541UA-RB51 RAM Replacement: 5 단계, 이미지 1/2 Asus R541UA-RB51 RAM Replacement: 5 단계, 이미지 2/2
    • Gently slide the CD drive away and pull up to remove it from the computer.
  6. Asus R541UA-RB51 RAM Replacement, Hard Drive: 6 단계, 이미지 1/2 Asus R541UA-RB51 RAM Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
    • Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
  7. Asus R541UA-RB51 RAM Replacement, RAM: 7 단계, 이미지 1/1
    • Remove all fourteen 4.3 mm screws from the motherboard. Use a Phillips #1 screwdriver to remove the screws.
  8. Asus R541UA-RB51 RAM Replacement: 8 단계, 이미지 1/3 Asus R541UA-RB51 RAM Replacement: 8 단계, 이미지 2/3 Asus R541UA-RB51 RAM Replacement: 8 단계, 이미지 3/3
    • Unplug the three connections from the top of the motherboard.
    • Lift up at an angle to remove the motherboard from the computer. Take caution when lifting the areas where the USB ports are located. They are in small slots that exit the computer's main body. They will need to be slid through these slots to remove the motherboard.
  9. Asus R541UA-RB51 RAM Replacement: 9 단계, 이미지 1/3 Asus R541UA-RB51 RAM Replacement: 9 단계, 이미지 2/3 Asus R541UA-RB51 RAM Replacement: 9 단계, 이미지 3/3
    • Locate the RAM slot on the underside of the motherboard. This device did not have a RAM card so a piece of cardboard was used as a substitute.
    • Replace the current card with the new RAM card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Drew Singleton
회원 가입일: 08/31/18
359 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 29
전체 시간: 2,067
