소개
This guide is for the replacement or upgrade of the RAM card.
필요한 것
Flip the laptop over so that the back panel is facing up.
Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
Unplug the three connections from the top of the motherboard.
Lift up at an angle to remove the motherboard from the computer. Take caution when lifting the areas where the USB ports are located. They are in small slots that exit the computer's main body. They will need to be slid through these slots to remove the motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
