주요 콘텐츠로 건너뛰기
Asus R558UQ-DM513D SSD Replacement
필요한 것
  1. Asus R558UQ-DM513D SSD Replacement, HDD (Hard Disk Drive): 1 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the single 5 mm screw and remove the RAM access panel.
    • Remove the ten 5 mm screws using the same Phillips #0 screwdriver.
  2. Asus R558UQ-DM513D SSD Replacement: 2 단계, 이미지 1/1
    • Remove two 2 mm hidden screws using the Phillips #0 screwdriver.
  3. Asus R558UQ-DM513D SSD Replacement: 3 단계, 이미지 1/1
    • Remove the back cover of the laptop to expose the inner components.
  4. Asus R558UQ-DM513D SSD Replacement: 4 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the HDD in place.
  5. Asus R558UQ-DM513D SSD Replacement: 5 단계, 이미지 1/1
    • Gently take the left-side board containing the ports by simply sliding it in and taking it out while still connected to the wire.
  6. Asus R558UQ-DM513D SSD Replacement: 6 단계, 이미지 1/1
    • Slide the HDD out.
결론
Deepanker Seth
회원 가입일: 12/05/20
133 평판
안내서 1개 작성함
CSU Los Angeles, Team S12-G4, Harris Fall 2020 CSU Los Angeles, Team S12-G4, Harris Fall 2020 회원
CSULA-HARRIS-F20S12G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 49
전체 시간: 1,442
