필요한 것
The first step to remove the keyboard is to remove 8 Philips screws on the bottom of the laptop.
Step two is to carefully pry the keyboard loose from the bottom of the laptop. Be careful while lifting the keyboard since it is still wired to the motherboard.
Lastly disconnect both the touchpad and the keyboard wires. Now the keyboard can be lifted completely out of the way.
This should be the view right now. The battery is located near the screen.
Second, disconnect the wires between the battery and the motherboard.
Next, unscrew the two Philips screws holding the battery in place.
By tilting the battery towards the screen the battery can be lifted out of the laptop.
Place the new battery where the old one was located tilted towards the screen.
Tilt the battery staight and fasten the two Philips screws holding the battery in place.
Reattach the wires to the motherboard.
Reconnect the keyboard and touchpad connectors.
Fix the keyboard to the bottom of the laptop by gently pressing the together.
Screw the 8 Philips screws back into the bottom of the laptop and you're done.
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde.
다른 한 분이 해당 안내서를 완성하였습니다.
