주요 콘텐츠로 건너뛰기
Asus ROG Ally Left RGB Thumbstick Ring Replacement
필요한 것
  1. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Prepare your device for disassembly: 1 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Prepare your device for disassembly: 1 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Prepare your device for disassembly: 1 단계, 이미지 3개 중 3개
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • If you have a microSD card installed, remove it. The card can easily be damaged when removing the motherboard.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the back cover: 2 단계, 이미지 2개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the back cover: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $36.95
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Release the back cover's clips: 4 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Release the back cover's clips: 4 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Release the back cover's clips: 4 단계, 이미지 3개 중 3개
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the back cover: 5 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the back cover: 5 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the back cover: 5 단계, 이미지 3개 중 3개
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  6. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the plastic cover: 6 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the plastic cover: 6 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the plastic cover: 6 단계, 이미지 3개 중 3개
    • Use your fingers to peel up and remove the black plastic cover between the fans.
    • Put the cover aside—you'll use it during reassembly.
  7. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unlatch the locking bar: 7 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unlatch the locking bar: 7 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unlatch the locking bar: 7 단계, 이미지 3개 중 3개
    • A metal locking bar secures the top edge of the battery connector
    • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
  8. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 3개
    • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
    • Insert the flat end of a spudger under the center of the battery connector.
    • Lift the connector straight up and out of its socket to disconnect the battery.
    • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
  9. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the battery: 9 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the battery: 9 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the battery: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a Phillips #00 screwdriver to remove the four screws securing the battery:
    • Two 9.6 mm‑long screws near the center of the top edge
    • The screw near the left speaker has a warning sticker on it. Pierce through it with your screwdriver or use tweezers to remove it.
    • Two 3.4 mm‑long screws at the left and right edges
  10. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the battery: 10 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the battery: 10 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the battery: 10 단계, 이미지 3개 중 3개
    • With one hand, hold the ribbon cable that runs along the top of the battery out of the way.
    • With your free hand, lift the battery straight up and remove it.
  11. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Separate the fan tape: 11 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Separate the fan tape: 11 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Separate the fan tape: 11 단계, 이미지 3개 중 3개
    • The left fan will be on your right-hand side since your device is laying upside down.
    • Insert the point of a spudger between the tape on the upper edge of the fan and the heatsink foam.
    • Slide the spudger under the length of the tape to separate it from the foam.
    • During reassembly, press the tape back into place to secure it to the heatsink foam.
  12. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the left fan: 12 단계, 이미지 2개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the left fan: 12 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the 9.6 mm‑long screw securing the left fan.
  13. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Reposition the left fan: 13 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Reposition the left fan: 13 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Reposition the left fan: 13 단계, 이미지 3개 중 3개
    • Gently lift the fan and set it on top of the heatsink foam so you can access the fan cables.
    • Be very careful not to strain the cables, as they can easily be damaged.
  14. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the fan cable tape: 14 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the fan cable tape: 14 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the fan cable tape: 14 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be very careful not to scrape off or damage any of the components on the motherboard during the next two steps.
    • Use tweezers to peel up and remove the piece of tape securing the fan cables to the motherboard.
    • Put the tape aside. You'll use it during reassembly.
  15. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the left fan: 15 단계, 이미지 2개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the left fan: 15 단계, 이미지 2개 중 2개
    • Use angled tweezers to pull the fan cable connector straight out of its socket.
    • If you're having trouble, gently rock the connector side-to-side to help loosen it.
  16. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the left fan: 16 단계, 이미지 1개 중 1개
    • Remove the left fan.
    • If your replacement fan doesn't come with tape installed, transfer it from the old fan.
  17. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Separate the fan tape: 17 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Separate the fan tape: 17 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Separate the fan tape: 17 단계, 이미지 3개 중 3개
    • The right fan will be on your left-hand side since your device is laying upside down.
  18. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the right fan: 18 단계, 이미지 2개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the right fan: 18 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the 9.6 mm‑long screw securing the right fan.
  19. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Reposition the right fan: 19 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Reposition the right fan: 19 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Reposition the right fan: 19 단계, 이미지 3개 중 3개
  20. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the fan cable tape: 20 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the fan cable tape: 20 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the fan cable tape: 20 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
  21. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the right fan: 21 단계, 이미지 2개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the right fan: 21 단계, 이미지 2개 중 2개
  22. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the right fan: 22 단계, 이미지 1개 중 1개
    • Remove the right fan.
  23. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the thumbstick interconnect cable: 23 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the thumbstick interconnect cable: 23 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the thumbstick interconnect cable: 23 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The right thumbstick will be on your left-hand side since your device is laying upside down.
    • Use a spudger or a clean fingernail to lift the locking flap on the thumbstick interconnect cable ZIF connector, located on the right thumbstick board.
    • Use tweezers to grip the cable's blue pull tab and pull the connector straight out of its socket.
  24. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the right thumbstick ring: 24 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the right thumbstick ring: 24 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the right thumbstick ring: 24 단계, 이미지 3개 중 3개
    • Use the point of a spudger to lift the locking flap on the right thumbstick ring ZIF connector.
    • The black line on the ZIF connector cables mark the connection area. During reassembly, insert the cables into their sockets up to this line.
  25. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the right thumbstick assembly: 25 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the right thumbstick assembly: 25 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the right thumbstick assembly: 25 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the four 3.4 mm‑long screws securing the right thumbstick assembly.
    • During reassembly, keep the left edge of your device lifted while you tighten the screws so the thumbstick doesn't press against your workspace and pop out of place.
  26. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the right thumbstick assembly: 26 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the right thumbstick assembly: 26 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the right thumbstick assembly: 26 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the bottom left edge of the thumbstick assembly and the chassis.
    • Pry up the thumbstick assembly and remove it, making sure to thread the thumbstick ring cable through its cutout.
    • During reassembly:
    • Orient the board over your device thumbstick side down.
    • Thread the thumbstick ring cable through its cutout on the board.
    • Lift the left edge of your device and push the thumbstick assembly firmly into place so the small circular cutouts on the left edge go over their alignment posts. The board should stay firmly in place.
  27. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the thumbstick interconnect cable: 27 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the thumbstick interconnect cable: 27 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the thumbstick interconnect cable: 27 단계, 이미지 3개 중 3개
    • Use a spudger or a clean fingernail to lift the locking flap on the thumbstick interconnect cable ZIF connector, located on the left thumbstick board.
  28. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the thumbstick interconnect cable: 28 단계, 이미지 1개 중 1개
    • Remove the thumbstick interconnect cable and set it aside for reassembly.
  29. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the left thumbstick ring: 29 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the left thumbstick ring: 29 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the left thumbstick ring: 29 단계, 이미지 3개 중 3개
    • Use the point of a spudger to lift the locking flap on the left thumbstick ring ZIF connector.
  30. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Peel up the main board interconnect cable tape: 30 단계, 이미지 2개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Peel up the main board interconnect cable tape: 30 단계, 이미지 2개 중 2개
    • Use tweezers to peel up the tape covering the main board interconnect cable ZIF connector.
  31. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the main board interconnect cable: 31 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the main board interconnect cable: 31 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the main board interconnect cable: 31 단계, 이미지 3개 중 3개
    • Use a spudger or a clean fingernail to lift the locking flap on the main board interconnect cable ZIF connector.
  32. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the left thumbstick assembly: 32 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the left thumbstick assembly: 32 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the left thumbstick assembly: 32 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the four 3.4 mm‑long screws securing the left thumbstick assembly.
    • During reassembly, keep the right edge of your device lifted while you tighten the screws so the thumbstick doesn't press against your workspace and pop out of place.
  33. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the left thumbstick assembly: 33 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the left thumbstick assembly: 33 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the left thumbstick assembly: 33 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the bottom right edge of the thumbstick assembly and the chassis.
    • Pry up the thumbstick assembly and remove it.
    • Lift the right edge of your device and push the thumbstick assembly firmly into place so the small circular cutouts on the right edge go over their alignment posts. The board should stay firmly in place.
  34. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the screen: 34 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the screen: 34 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the screen: 34 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger or a clean fingernail to lift the locking flap on the screen cable ZIF connector, located on the bottom left corner of the motherboard.
    • Use tweezers to grip the cable's orange pull tab and pull the connector straight out of its socket.
  35. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the power button: 35 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the power button: 35 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the power button: 35 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the power button press connector from the middle of the motherboard's top edge.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't try to force the connector into place. A misaligned connector can bend the pins and cause permanent damage.
  36. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the speakers: 36 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the speakers: 36 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the speakers: 36 단계, 이미지 3개 중 3개
  37. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the antennas: 37 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the antennas: 37 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Disconnect the antennas: 37 단계, 이미지 3개 중 3개
    • Slide one arm of your angled tweezers under the metal neck of one of the antenna cables coaxial connectors, near the top left corner of the motherboard.
    • Lift only on the metal sections of the connectors. Don't lift the cables themselves.
    • Gently lift straight up to disconnect the cable.
    • Repeat the disconnection process for the other antenna cable.
  38. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the motherboard: 38 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the motherboard: 38 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the motherboard: 38 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the nine 3.4 mm‑long screws securing the motherboard.
  39. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the motherboard: 39 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the motherboard: 39 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the motherboard: 39 단계, 이미지 3개 중 3개
    • If you have a microSD card installed, make sure to remove it before continuing.
    • With one hand, firmly secure your device.
    • With your free hand, lift the bottom edge of the motherboard and pull it towards the bottom of the chassis to remove it.
    • With one hand, lift the top edge of your device so the actions buttons and D-Pad aren't touching your work surface.
    • Visually check that all the buttons are fully and properly in their recesses. If they aren't, they won't press correctly.
    • With your device lifted, use your free hand to slide the motherboard into place at a slight downward angle.
    • Make sure the bumper buttons near the upper corners go under the plastic bumpers and the ports along the top edge go into their cutouts.
  40. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the left RGB thumbstick ring: 40 단계, 이미지 2개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Unfasten the left RGB thumbstick ring: 40 단계, 이미지 2개 중 2개
    • The left thumbstick ring will be on your right-hand side since your device is laying upside down.
    • Use a Phillips #00 screwdriver to remove the three 3.4 mm‑long screws securing the left RGB thumbstick ring.
  41. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the left RGB thumbstick ring: 41 단계, 이미지 2개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the left RGB thumbstick ring: 41 단계, 이미지 2개 중 2개
    • Lift the thumbstick ring straight up and remove it.
  42. Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the left RGB thumbstick ring cable: 42 단계, 이미지 3개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the left RGB thumbstick ring cable: 42 단계, 이미지 3개 중 2개 Asus ROG Ally Left RGB Thumbstick Ring Replacement, Remove the left RGB thumbstick ring cable: 42 단계, 이미지 3개 중 3개
    • If your replacement thumbstick ring doesn't come with a cable, follow the next two steps to remove and transfer the old one.
    • With one hand, firmly secure the thumbstick ring.
    • With your free hand, use the point of a spudger to flip up the locking flap on the thumbstick ring ZIF connector.
  43. Asus ROG Ally Left RGB Thumbstick Ring Replacement: 43 단계, 이미지 2개 중 1개 Asus ROG Ally Left RGB Thumbstick Ring Replacement: 43 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to gently pull the cable straight out of its socket and remove it.
    • The black line on the ZIF connector cable marks the connection area. During reassembly, insert the cable into its socket up to this line.
결론
작성자
3다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
155,120 평판
안내서 1,033개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 18
지난 30일: 80
전체 시간: 1,490
