주요 콘텐츠로 건너뛰기
Asus ROG FX60VM Hard Drive Replacement
필요한 것
  1. Asus ROG FX60VM Hard Drive Replacement, HDD: 1 단계, 이미지 1/2 Asus ROG FX60VM Hard Drive Replacement, HDD: 1 단계, 이미지 2/2
    • Before disassembling the laptop, turn the laptop off and make sure it's unplugged from the power supply.
  2. Asus ROG FX60VM Hard Drive Replacement: 2 단계, 이미지 1/3 Asus ROG FX60VM Hard Drive Replacement: 2 단계, 이미지 2/3 Asus ROG FX60VM Hard Drive Replacement: 2 단계, 이미지 3/3
    • Flip the laptop over so the back case is facing up.
    • Remove the ten 2.5 mm screws from the back case using a Phillips #0 screwdriver.
    • Use a plastic opening tool and picks to pry the back panel off of the device.
  3. Asus ROG FX60VM Hard Drive Replacement: 3 단계, 이미지 1/3 Asus ROG FX60VM Hard Drive Replacement: 3 단계, 이미지 2/3 Asus ROG FX60VM Hard Drive Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    구매
    • Put the tip of Halberd spudger under the battery connector and lift it gently to disconnect it from the motherboard.
    • You may need to wiggle the spudger up and down in order to disconnect the battery connector.
  4. Asus ROG FX60VM Hard Drive Replacement: 4 단계, 이미지 1/2 Asus ROG FX60VM Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove the four 3.0 mm screws from the HDD case using a Phillips #1 screwdriver.
  5. Asus ROG FX60VM Hard Drive Replacement: 5 단계, 이미지 1/3 Asus ROG FX60VM Hard Drive Replacement: 5 단계, 이미지 2/3 Asus ROG FX60VM Hard Drive Replacement: 5 단계, 이미지 3/3
    • Do not lift the HDD up, as you may damage the connector highlighted in red.
    • Hold the back of the HDD , and slide it out of the port to disconnect it from the motherboard.
  6. Asus ROG FX60VM Hard Drive Replacement: 6 단계, 이미지 1/3 Asus ROG FX60VM Hard Drive Replacement: 6 단계, 이미지 2/3 Asus ROG FX60VM Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the two 3.0 mm screws on each side of the HDD mounting bracket using a Phillips #1 screwdriver.
    • Lift the HDD out of the mounting bracket, and install a new HDD or SSD to the mounting bracket.
결론
After install a new HDD or SSD, for better performace, initialize the new disk.
다른 한 분이 해당 안내서를 완성하였습니다.
JingZhao Liang
회원 가입일: 06/26/22
163 평판
안내서 1개 작성함
York University, Team M-13, Allen Summer 2022 York University, Team M-13, Allen Summer 2022 회원
YORK-ALLEN-SU22SMG13
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Thank you so much JingZhao Liang for the concise and to the point guide. It's easy to follow and I am very impressed that you mentioned how to dispose the e-waste properly in conclusion part.
Tayyaba Riasat - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 27
전체 시간: 504
