주요 콘텐츠로 건너뛰기
Asus ROG G53SW-XT1 Hard Drive Replacement
필요한 것
  1. Asus ROG G53SW-XT1 Hard Drive  Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug the power cable and flip the computer over.
  2. Asus ROG G53SW-XT1 Hard Drive  Replacement: 2 단계, 이미지 1/1
    • Unlock the battery by pushing the switch to the right.
  3. Asus ROG G53SW-XT1 Hard Drive  Replacement: 3 단계, 이미지 1/2 Asus ROG G53SW-XT1 Hard Drive  Replacement: 3 단계, 이미지 2/2
    • Push and hold the left switch, then pull the battery out.
  4. Asus ROG G53SW-XT1 Hard Drive  Replacement, Keyboard: 4 단계, 이미지 1/3 Asus ROG G53SW-XT1 Hard Drive  Replacement, Keyboard: 4 단계, 이미지 2/3 Asus ROG G53SW-XT1 Hard Drive  Replacement, Keyboard: 4 단계, 이미지 3/3
    • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
  5. Asus ROG G53SW-XT1 Hard Drive  Replacement: 5 단계, 이미지 1/3 Asus ROG G53SW-XT1 Hard Drive  Replacement: 5 단계, 이미지 2/3 Asus ROG G53SW-XT1 Hard Drive  Replacement: 5 단계, 이미지 3/3
    • Disconnect the keyboard ribbon cables from the motherboard.
  6. Asus ROG G53SW-XT1 Hard Drive  Replacement, Back Panel: 6 단계, 이미지 1/3 Asus ROG G53SW-XT1 Hard Drive  Replacement, Back Panel: 6 단계, 이미지 2/3 Asus ROG G53SW-XT1 Hard Drive  Replacement, Back Panel: 6 단계, 이미지 3/3
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  7. Asus ROG G53SW-XT1 Hard Drive  Replacement: 7 단계, 이미지 1/1
    • Remove the fourteen Phillips #0 screws.
  8. Asus ROG G53SW-XT1 Hard Drive  Replacement: 8 단계, 이미지 1/2 Asus ROG G53SW-XT1 Hard Drive  Replacement: 8 단계, 이미지 2/2
    • Flip the laptop over and pull off the bottom cover.
  9. Asus ROG G53SW-XT1 Hard Drive  Replacement, Hard Drive: 9 단계, 이미지 1/2 Asus ROG G53SW-XT1 Hard Drive  Replacement, Hard Drive: 9 단계, 이미지 2/2
    • Place your fingers along the left edge of the hard drive cover, and slide it to the right, then lift up.
  10. Asus ROG G53SW-XT1 Hard Drive  Replacement: 10 단계, 이미지 1/3 Asus ROG G53SW-XT1 Hard Drive  Replacement: 10 단계, 이미지 2/3 Asus ROG G53SW-XT1 Hard Drive  Replacement: 10 단계, 이미지 3/3
    • Remove the Hard Drive and case from the laptop.
    • Remove the four Phillips #0 screws from the hard drive case.
  11. Asus ROG G53SW-XT1 Hard Drive  Replacement: 11 단계, 이미지 1/1
    • Slide the hard drive out of the casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alexander Lovrien
회원 가입일: 02/12/18
218 평판
안내서 1개 작성함
댓글 한 개
Bottom cover holds only by 9 screws. You don’t need to remove 14 screws. All screws at the bottom with M2 5x7 label (do not remove two small screws. And one scre on the right in the middle without number on the metal plate). You don’t need to remove screw with M2 5x7 label on the right side, second from the corner.
John McCain - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 2,128
