주요 콘텐츠로 건너뛰기
Asus ROG G53SW-XT1 Optical Drive Replacement
필요한 것
  1. Asus ROG G53SW-XT1 Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug the power cable and flip the computer over.
  2. Asus ROG G53SW-XT1 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Unlock the battery by pushing the switch to the right.
  3. Asus ROG G53SW-XT1 Optical Drive Replacement: 3 단계, 이미지 1/2 Asus ROG G53SW-XT1 Optical Drive Replacement: 3 단계, 이미지 2/2
    • Push and hold the left switch, then pull the battery out.
  4. Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: 4 단계, 이미지 1/3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: 4 단계, 이미지 2/3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: 4 단계, 이미지 3/3
    • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
  5. Asus ROG G53SW-XT1 Optical Drive Replacement: 5 단계, 이미지 1/3 Asus ROG G53SW-XT1 Optical Drive Replacement: 5 단계, 이미지 2/3 Asus ROG G53SW-XT1 Optical Drive Replacement: 5 단계, 이미지 3/3
    • Disconnect the keyboard ribbon cables from the motherboard.
  6. Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: 6 단계, 이미지 1/3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: 6 단계, 이미지 2/3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: 6 단계, 이미지 3/3
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  7. Asus ROG G53SW-XT1 Optical Drive Replacement: 7 단계, 이미지 1/1
    • Remove the fourteen Phillips #0 screws.
  8. Asus ROG G53SW-XT1 Optical Drive Replacement: 8 단계, 이미지 1/2 Asus ROG G53SW-XT1 Optical Drive Replacement: 8 단계, 이미지 2/2
    • Flip the laptop over and pull off the bottom cover.
  9. Asus ROG G53SW-XT1 Optical Drive Replacement, Optical Drive: 9 단계, 이미지 1/1
    • Remove the single 7mm Phillips #0 screw holding the hard drive in place.
  10. Asus ROG G53SW-XT1 Optical Drive Replacement: 10 단계, 이미지 1/2 Asus ROG G53SW-XT1 Optical Drive Replacement: 10 단계, 이미지 2/2
    • Slide the hard drive out of the casing.
결론
Bailey Herring
회원 가입일: 02/21/18
393 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 220
