주요 콘텐츠로 건너뛰기
Asus ROG G55VW-DH71 Hard Drive Replacement
필요한 것
  1. Asus ROG G55VW-DH71 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Using the Phillips size 0 head screwdriver, remove the 2 3.6 mm screws on the back plate located on the bottom left portion of the back of the laptop.
  2. Asus ROG G55VW-DH71 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Lift up and remove the back plate that is located in the back, bottom left portion of the laptop.
  3. Asus ROG G55VW-DH71 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Using the Phillips size 0 remove both 4.6 mm screws from the metal tabs.
  4. Asus ROG G55VW-DH71 Hard Drive Replacement: 4 단계, 이미지 1/2 Asus ROG G55VW-DH71 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Grab the plastic tab.
    • Gently pull towards the outer edge of the device.
    • Lift out to fully remove.
결론
Savanna Stockman
회원 가입일: 01/16/19
641 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 14
전체 시간: 725
