주요 콘텐츠로 건너뛰기
Asus ROG G55VW-DH71 RAM Replacement
필요한 것
  1. Asus ROG G55VW-DH71 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Flip the device over so that the bottom of the computer is easily accessible.
    • Using the Phillips size 0 head screwdriver, remove both 3.6mm. screws on the back plate located on the bottom left portion of the back of the laptop.
  2. Asus ROG G55VW-DH71 RAM Replacement: 2 단계, 이미지 1/1
    • Lift up and remove the back plate from the device.
  3. Asus ROG G55VW-DH71 RAM Replacement: 3 단계, 이미지 1/1
    • Gently pry apart the two white clips, that are holding in the RAM cards in, outwards.
  4. Asus ROG G55VW-DH71 RAM Replacement: 4 단계, 이미지 1/1
    • Lift then gently pull out the RAM card.
결론
Savanna Stockman
회원 가입일: 01/16/19
641 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 12
전체 시간: 668
