주요 콘텐츠로 건너뛰기
Asus ROG G55VW-DH71 Sound Bar Replacement
필요한 것
  1. Asus ROG G55VW-DH71 Sound Bar  Replacement, Sound Bar: 1 단계, 이미지 1/2 Asus ROG G55VW-DH71 Sound Bar  Replacement, Sound Bar: 1 단계, 이미지 2/2
    • Side the switch and lift the battery from the back of the device.
  2. Asus ROG G55VW-DH71 Sound Bar  Replacement: 2 단계, 이미지 1/2 Asus ROG G55VW-DH71 Sound Bar  Replacement: 2 단계, 이미지 2/2
    • Using the PH0 screw driver remove both 4.4 mm screws.
    • Using the PH0 screw driver remove the 6.4 mm screw.
  3. Asus ROG G55VW-DH71 Sound Bar  Replacement: 3 단계, 이미지 1/2 Asus ROG G55VW-DH71 Sound Bar  Replacement: 3 단계, 이미지 2/2
    • Using the iFixit opening tool, gently pry open the plate covering the spine of the device.
  4. Asus ROG G55VW-DH71 Sound Bar  Replacement: 4 단계, 이미지 1/1
    • Using the PH 00 screwdriver, remove the three 10.6 mm screws holding the sound bar down.
  5. Asus ROG G55VW-DH71 Sound Bar  Replacement: 5 단계, 이미지 1/2 Asus ROG G55VW-DH71 Sound Bar  Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the bent black tweezers, remove both wires connecting the sound bar to the motherboard.
결론
Savanna Stockman
회원 가입일: 01/16/19
641 평판
안내서 5개 작성하였습니다
댓글 한 개
Excellent tutorial. Thank you for your help.Excellent tutorial. Thank you for your help. I lost the back cover of my g55. I couldn't find a spare part here in Brazil.
Welington Faria - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 305
