주요 콘텐츠로 건너뛰기
Asus ROG G56JK Fan Replacement
필요한 것
  1. Asus ROG G56JK Fan Replacement, Battery: 1 단계, 이미지 1/2 Asus ROG G56JK Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK Fan Replacement, Hard Drive: 2 단계, 이미지 1/1
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK Fan Replacement: 3 단계, 이미지 1/1
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK Fan Replacement, Back Panel: 4 단계, 이미지 1/1
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK Fan Replacement: 5 단계, 이미지 1/1
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK Fan Replacement, Fan: 6 단계, 이미지 1/2 Asus ROG G56JK Fan Replacement, Fan: 6 단계, 이미지 2/2
    • Unplug the red and yellow wires from the port in the motherboard.
    • Lightly pull on the red and yellow wires to release.
  7. Asus ROG G56JK Fan Replacement: 7 단계, 이미지 1/1
    • Remove the 5mm screw.
    • Remove the 4mm screw.
  8. Asus ROG G56JK Fan Replacement: 8 단계, 이미지 1/1
    • The fan is glued to the black box that it is inside of. When pulling the fan out, you may experience a small amount of tearing of the black box.
    • Gently pull the fan out of the black box.
결론
Jonathan McNary
회원 가입일: 09/26/18
269 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 12
전체 시간: 1,767
