주요 콘텐츠로 건너뛰기
Asus ROG G74SX-DH73-3D Battery Replacement
필요한 것
  1. Asus ROG G74SX-DH73-3D Battery Replacement, Battery: 1 단계, 이미지 1/3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: 1 단계, 이미지 2/3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: 1 단계, 이미지 3/3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
결론
Jackson Reynolds
회원 가입일: 09/18/18
346 평판
안내서 3개 작성하였습니다
University of North Texas, Team S3-G7, Raign Fall 2018 University of North Texas, Team S3-G7, Raign Fall 2018 회원
UNT-RAIGN-F18S3G7
3 회원들
안내서 4개 작성하였습니다
댓글 2개
The note bullet should just be a bullet. Check grammar on the Red bullet.
Joseph McCoy - 답글
“With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” The sentence is too wordy you can remove “Where you can see the battery pop slightly up”.
Nicholas Ivey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 354
