주요 콘텐츠로 건너뛰기
Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement
필요한 것
  1. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: 1 단계, 이미지 1/2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: 1 단계, 이미지 2/2
    • Place the device upside-down. Unscrew the screw at the top of the cover and remove the cover by using a plastic opening tool.
  2. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: 2 단계, 이미지 1/1
    • Remove the screw that is located on the right edge of the removed cover. The screw is in a small opening.
  3. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: 3 단계, 이미지 1/2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: 3 단계, 이미지 2/2
    • Inside the opening that the screw was in, use a nylon spudger or any thin tool to push against the inside edge of the disc/optical drive.
    • With the disc/optical drive slightly popped out of the socket, pull the rest of it out by hand.
결론
Jackson Reynolds
회원 가입일: 09/18/18
346 평판
안내서 3개 작성하였습니다
University of North Texas, Team S3-G7, Raign Fall 2018 University of North Texas, Team S3-G7, Raign Fall 2018 회원
UNT-RAIGN-F18S3G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 232
