주요 콘텐츠로 건너뛰기
Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement
필요한 것
  1. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: 1 단계, 이미지 1/3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: 1 단계, 이미지 2/3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: 1 단계, 이미지 3/3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
  2. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: 2 단계, 이미지 1/2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: 2 단계, 이미지 2/2
    • Remove the large flathead screw holding the back cover in place.
    • Pull the cover off by prying it open starting from the top center and moving outwards.
  3. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 3 단계, 이미지 1/2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 3 단계, 이미지 2/2
    • Remove the eight short screws holding in the two metal covers near the bottom.
    • Remove the two metal covers.
  4. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 4 단계, 이미지 1/2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 4 단계, 이미지 2/2
    • Remove the battery to access the screws under it.
    • Remove these 16 screws with a regular Phillips head screw-driver.
    • These Phillips head screws will require a longer bit or an extension.
  5. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 5 단계, 이미지 1/2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 5 단계, 이미지 2/2
    • Flip the device back over.
    • Pull off the plastic cover behind the screen.
    • Remove the four Phillips head screws holding the screen in place.
  6. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 6 단계, 이미지 1/2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 6 단계, 이미지 2/2
    • With the screen removed, pry the piece that has the keyboard and the track pad on it.
  7. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 7 단계, 이미지 1/2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 7 단계, 이미지 2/2
    • Remove the two Phillips head screws holding the buttons in place.
결론
Josh Reyes
회원 가입일: 09/18/18
183 평판
안내서 1개 작성함
University of North Texas, Team S3-G7, Raign Fall 2018 University of North Texas, Team S3-G7, Raign Fall 2018 회원
UNT-RAIGN-F18S3G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 370
