주요 콘텐츠로 건너뛰기
Asus ROG G750JH-DB71 Graphics Card Replacement
필요한 것
  1. Asus ROG G750JH-DB71 Graphics Card Replacement, Battery: 1 단계, 이미지 1/2 Asus ROG G750JH-DB71 Graphics Card Replacement, Battery: 1 단계, 이미지 2/2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 Graphics Card Replacement: 2 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 2 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 2 단계, 이미지 3/3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 Graphics Card Replacement, Asus ROG G750JH-DB71: 3 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement, Asus ROG G750JH-DB71: 3 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement, Asus ROG G750JH-DB71: 3 단계, 이미지 3/3
    • Use a spudger or your finger to lift up the plastic cover on the bottom of the laptop.
    • Under the plastic cover is a captive screw; unscrew it using a Phillips #00 screwdriver.
  4. Asus ROG G750JH-DB71 Graphics Card Replacement: 4 단계, 이미지 1/2 Asus ROG G750JH-DB71 Graphics Card Replacement: 4 단계, 이미지 2/2
    • Remove the cover.
    • If your goal is to replace/remove only the hard drive, you don't have to complete the following disassembly steps and can go on to the hard drive replacement guide.
  5. Asus ROG G750JH-DB71 Graphics Card Replacement: 5 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 5 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 5 단계, 이미지 3/3
    • Remove the hard drive by unscrewing the 4.4 mm Phillips #00 screws.
    • Remove all of the plastic caps around the edges using a spudger. Remove the screws underneath the caps.
    • There is one 13 mm Phillips #00 screw and six 8 mm Phillips #00 screws.
    • Remove the remaining screws underneath the cover.
    • There are six 8 mm Phillips #00 screws and three 1 mm Phillips #00 screws.
  6. Asus ROG G750JH-DB71 Graphics Card Replacement: 6 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 6 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 6 단계, 이미지 3/3
    • You will find a metal tab holding the disc drive in place. Push on the tab with a spudger to remove the disc drive. It is located below a previously removed screw.
    • Do not pull the disc drive out from the side before pushing the metal tab as it will only damage the cover.
    • Remove the three 4 mm Phillips #00 screws that were previously covered by the disc drive.
  7. Asus ROG G750JH-DB71 Graphics Card Replacement: 7 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 7 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 7 단계, 이미지 3/3
    • The back cover can be taken off by hand.
    • Disconnect the speaker cables.
    • Remove two 8 mm Phillips #00 screws on each corner.
  8. Asus ROG G750JH-DB71 Graphics Card Replacement: 8 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 8 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 8 단계, 이미지 3/3
    • Pry the keyboard gently using a spudger.
    • Make sure to unhook the cables and wires from the keyboard gently in Picture 3.
  9. Asus ROG G750JH-DB71 Graphics Card Replacement: 9 단계, 이미지 1/2 Asus ROG G750JH-DB71 Graphics Card Replacement: 9 단계, 이미지 2/2
    • Now you can pull the keyboard off but make sure to do so carefully without damaging or scuffing any components.
    • Pull up and out at an angle to avoid damaging the internals of the laptop.
  10. Asus ROG G750JH-DB71 Graphics Card Replacement, Fan: 10 단계, 이미지 1/1
    • Remove the Data and Wi-fi cables from the sockets shown.
  11. Asus ROG G750JH-DB71 Graphics Card Replacement: 11 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 11 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 11 단계, 이미지 3/3
    • Slowly close the lid and turn the device around.
    • Remove the 6 screws (3 on each side) from the edges of the device. (8mm Phillips 00)
    • Remove the Webcam cable.
  12. Asus ROG G750JH-DB71 Graphics Card Replacement: 12 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 12 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 12 단계, 이미지 3/3
    • Carefully lift the lid away from the rest of the device.
    • There may be tape covering the fans or other components. Remove it slowly as to not damage anything.
  13. Asus ROG G750JH-DB71 Graphics Card Replacement: 13 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 13 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 13 단계, 이미지 3/3
    • Remove the three screws surrounding each fan shown along with the ribbon cables connecting them to the motherboard. (4mm Phillips 00)
    • Remove the USB port board blocking the rightmost fan.
    • Remove the fans from the board.
  14. Asus ROG G750JH-DB71 Graphics Card Replacement, Graphics Card: 14 단계, 이미지 1/2 Asus ROG G750JH-DB71 Graphics Card Replacement, Graphics Card: 14 단계, 이미지 2/2
    • Use a Phillips #00 to remove seven 4.0 mm screws connecting the motherboard to the case.
    • Disconnect the cables still attached to the main board.
  15. Asus ROG G750JH-DB71 Graphics Card Replacement: 15 단계, 이미지 1/2 Asus ROG G750JH-DB71 Graphics Card Replacement: 15 단계, 이미지 2/2
    • Slowly lift the main board out of the chassis.
  16. Asus ROG G750JH-DB71 Graphics Card Replacement: 16 단계, 이미지 1/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 16 단계, 이미지 2/3 Asus ROG G750JH-DB71 Graphics Card Replacement: 16 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws connecting to the heat sink.
    • Use a Phillips #00 screwdriver to remove the three 1 mm screws connected to the board.
    • Lift the graphics card off to remove it from the main board.
결론
James Mills
회원 가입일: 10/25/22
471 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S5G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 34
전체 시간: 312
