주요 콘텐츠로 건너뛰기
Asus ROG G750JH-DB71 Hard Drive Replacement
필요한 것
  1. Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 Hard Drive Replacement: 2 단계, 이미지 1/3 Asus ROG G750JH-DB71 Hard Drive Replacement: 2 단계, 이미지 2/3 Asus ROG G750JH-DB71 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Use a pick or your finger to lift up the plastic cover on back of the laptop.
    • Under the plastic cover is a screw, unscrew it using a Phillips #00 screwdriver.
    • The screw has a c lock so it can not be unscrewed completely. Once Its loose pry on the seam using a screwdriver or the iFixit pry tool.
  4. Asus ROG G750JH-DB71 Hard Drive Replacement: 4 단계, 이미지 1/3 Asus ROG G750JH-DB71 Hard Drive Replacement: 4 단계, 이미지 2/3 Asus ROG G750JH-DB71 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove the cover.
    • Remove the four 4.0 mm Phillips #00 screws holding in the hard drive caddy.
    • Push the caddy towards the open space in its compartment to remove it.
결론
Devin Medeiros
회원 가입일: 10/25/22
219 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S5G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 153
