주요 콘텐츠로 건너뛰기
Asus ROG G750JM-BS17N23 Hard Drive Replacement
필요한 것
  1. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Back Plate: 1 단계, 이미지 1/1
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  2. Asus ROG G750JM-BS17N23 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  3. Asus ROG G750JM-BS17N23 Hard Drive Replacement: 3 단계, 이미지 1/3 Asus ROG G750JM-BS17N23 Hard Drive Replacement: 3 단계, 이미지 2/3 Asus ROG G750JM-BS17N23 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
  4. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • To access the hard drive, remove the back plate.
  5. Asus ROG G750JM-BS17N23 Hard Drive Replacement: 5 단계, 이미지 1/2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Remove the three 4mm Phillips #2 screws.
  6. Asus ROG G750JM-BS17N23 Hard Drive Replacement: 6 단계, 이미지 1/2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out.
  7. Asus ROG G750JM-BS17N23 Hard Drive Replacement: 7 단계, 이미지 1/2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: 7 단계, 이미지 2/2
    • With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive.
결론
Tanner
회원 가입일: 09/21/18
919 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 467
