주요 콘텐츠로 건너뛰기
Asus ROG G750JM-BSI7N23 Motherboard Replacement
필요한 것
  1. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Soundbar/speaker: 1 단계, 이미지 1/2 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Soundbar/speaker: 1 단계, 이미지 2/2
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 2 단계, 이미지 1/2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 3 단계, 이미지 1/2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 3 단계, 이미지 2/2
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 4 단계, 이미지 1/2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 5 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 5 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 5 단계, 이미지 3/3
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 6 단계, 이미지 1/1
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
  7. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Back Plate: 7 단계, 이미지 1/1
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  8. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 8 단계, 이미지 1/1
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  9. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 9 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 9 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 9 단계, 이미지 3/3
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
  10. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Keyboard: 10 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Keyboard: 10 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Keyboard: 10 단계, 이미지 3/3
    • Remove the six 8mm Phillips #2 screws to remove the display.
    • Remove the two 4mm Phillips #2 screws.
  11. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 11 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 11 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 11 단계, 이미지 3/3
    • Remove the four rubber tabs circled in green on the bottom of the device.
    • Remove the five 4mm #2 Phillips screws.
    • Remove the two 8mm #2 Phillips screws.
    • Remove the two 1cm #2 Phillips screws.
  12. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 12 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 12 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 12 단계, 이미지 3/3
    • Pry around the keyboard on the top topside as shown to remove it from shell.
  13. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 13 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 13 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 13 단계, 이미지 3/3
    • Remove the four connectors using your pry tool.
    • The keyboard will now be separated from the main computer.
  14. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Motherboard: 14 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Motherboard: 14 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Motherboard: 14 단계, 이미지 3/3
    • First, remove the two 7mm #2 Phillips screws circled in red to fold the silver plate over.
    • Remove all the connectors shown in the orange squares. You may need to use your plastic opening tool for the smaller ones.
  15. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 15 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 15 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 15 단계, 이미지 3/3
    • Remove the three #2 Phillips screws from the small wireless card located in the top left.
  16. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 16 단계, 이미지 1/2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 16 단계, 이미지 2/2
    • Remove the three #2 Phillips screws from the small power button card in the top right.
  17. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 17 단계, 이미지 1/1
    • Remove the two #2 Phillips screws for the audio card located in the bottom right.
  18. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 18 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 18 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: 18 단계, 이미지 3/3
    • Remove all 8mm #2 Phillips screws .
    • Remove all 2mm #2 Phillips screws.
    • Remove all 3mm #2 Phillips screws.
    • Remove all 7mm #2 Phillips screws.
    • Remove all 4mm #2 Phillips screws.
  19. Asus ROG G750JM-BSI7N23 Motherboard Replacement: 19 단계, 이미지 1/1
    • When all the screws are removed, pry up on the edges of the circuit board. You may need your plastic opening tool to access the edges.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tanner
회원 가입일: 09/21/18
919 평판
안내서 5개 작성하였습니다
댓글 한 개
Outstanding and that's from someone who has been turning screws on computers from the 8086 chip to and IBM 4381 then wrote a few books on the subject. This is the best tutorial I've ever came across, now do the G752. It's my next project after I find a motherboard.
Bill - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 29
전체 시간: 1,693
