주요 콘텐츠로 건너뛰기
Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement
필요한 것
  1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: 1 단계, 이미지 1/2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: 1 단계, 이미지 2/2
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 2 단계, 이미지 1/2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 2 단계, 이미지 2/2
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 3 단계, 이미지 1/2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 3 단계, 이미지 2/2
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 4 단계, 이미지 1/2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 4 단계, 이미지 2/2
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 5 단계, 이미지 1/3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 5 단계, 이미지 2/3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 5 단계, 이미지 3/3
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: 6 단계, 이미지 1/1
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
결론
Tanner
회원 가입일: 09/21/18
919 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 388
