주요 콘텐츠로 건너뛰기
Asus ROG G751JL-BB17T29 Hard Drive Replacement
필요한 것
  1. Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Remove the RAM access door: 1 단계, 이미지 1/2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Remove the RAM access door: 1 단계, 이미지 2/2
    • Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
  2. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 2 단계, 이미지 1/1
    • Remove the 5.3 mm Phillips #00 screw securing the RAM access door.
    • This screw is held in the hole in the door with a washer and will not come out of the hole, even after you unscrew it.
  3. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 3 단계, 이미지 1/2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 3 단계, 이미지 2/2
    • Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
    • The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
  4. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 4 단계, 이미지 1/3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 4 단계, 이미지 2/3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 4 단계, 이미지 3/3
    • Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
    • Pry the door up to release the clips closest to the pick.
    • Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
  5. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 5 단계, 이미지 1/1
    • Remove the RAM access door.
  6. Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Hard Drive: 6 단계, 이미지 1/2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Remove the four 2.4 mm screws securing the left hard drive with a Phillips screwdriver.
    • Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector.
  7. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 7 단계, 이미지 1/3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 7 단계, 이미지 2/3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 7 단계, 이미지 3/3
    • Remove the four 2.4 mm screws securing the right hard drive housing with a Phillips screwdriver.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Miller
회원 가입일: 10/06/16
677 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-1, Sullivan Fall 2016 USF Tampa, Team 2-1, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G1
4 회원들
안내서 20개 작성하였습니다
댓글 한 개
Dose the Asus ROG G751JL have any m.2 port in there anywhere? And what is the maximum capacity of SSD use in the Asus ROG G751JL?
shohebulalam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 5,841
