소개
This guide will attempt to show the user how to safely remove and replace the keyboard without damaging any of the surrounding components.
필요한 것
Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
Pry the door up to release the clips closest to the pick.
Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
Remove the ten 5.2 mm screws holding the main panel in place, highlighted in the photo, with a Phillips screwdriver.
Remove the four 5.2 mm screws underneath the center panel, highlighted in the photo, with a Phillips screwdriver.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Great work, but you are missing the last few steps of the replacement as all you are showing is how to remove the upper assembly
