소개
Use this guide to remove or replace the optical drive in an Asus ROG G751JL.
필요한 것
Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
Pry the door up to release the clips closest to the pick.
Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
다른 한 분이 해당 안내서를 완성하였습니다.
