주요 콘텐츠로 건너뛰기
Asus ROG G751JL-BSI7T28 Fan Replacement
필요한 것
  1. Asus ROG G751JL-BSI7T28 Fan Replacement, Back Panel: 1 단계, 이미지 1/1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Fan Replacement: 2 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 Fan Replacement: 2 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 Fan Replacement: 2 단계, 이미지 3/3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: 3 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: 3 단계, 이미지 2/2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Fan Replacement: 4 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 Fan Replacement: 4 단계, 이미지 2/2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Fan Replacement: 5 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 Fan Replacement: 5 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 Fan Replacement: 5 단계, 이미지 3/3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Fan Replacement: 6 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 Fan Replacement: 6 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 Fan Replacement: 6 단계, 이미지 3/3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Fan Replacement: 7 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 Fan Replacement: 7 단계, 이미지 2/2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: 8 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: 8 단계, 이미지 2/2
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: 9 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: 9 단계, 이미지 2/2
    • Remove the fan's power cable by pulling carefully outward towards the fan.
  10. Asus ROG G751JL-BSI7T28 Fan Replacement: 10 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 Fan Replacement: 10 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 Fan Replacement: 10 단계, 이미지 3/3
    • Remove the 5mm Phillips #00 screw.
    • Pull up on the black tab connected to the fan. This will pull it away from the cooling fins, allowing it to be removed.
    • Remove the fan from the laptop.
결론
Kristen Gismondi
회원 가입일: 11/12/14
85,242 평판
안내서 215개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,077개 작성하였습니다
댓글 한 개
What's the fan model?
Andres Landazuri - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 19
전체 시간: 706
