소개
This guide will demonstrate how to replace the Asus ROG G751JL-BSI7T28 keyboard on your Asus laptop computer.
Symptoms of a broken keyboard include missing or unresponsive keys. Check that any unresponsive keys are clear of dust and debris as this can also lead to a lack of input.
This guide is compatible with the following ASUS models: G751J, G751JL, G751JM, G751JT, and G751JY. Compatible part numbers include: 0KNB0-E601US00 and ASM14C33USJ442.
Warning: Ensure your device is powered down before starting this guide to prevent any electrical injuries or damage to your computer.
필요한 것
With the laptop closed, turn it upside-down so the bottom is facing up toward you.
Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
Remove the keyboard from the laptop.
