주요 콘텐츠로 건너뛰기
Asus ROG G751JL-BSI7T28 USB Port Board Replacement
필요한 것
  1. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Back Panel: 1 단계, 이미지 1/1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 2 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 2 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 2 단계, 이미지 3/3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Display Assembly: 3 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Display Assembly: 3 단계, 이미지 2/2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 4 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 4 단계, 이미지 2/2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 5 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 5 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 5 단계, 이미지 3/3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 6 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 6 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 6 단계, 이미지 3/3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 7 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 7 단계, 이미지 2/2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Keyboard Assembly: 8 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Keyboard Assembly: 8 단계, 이미지 2/2
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Fan: 9 단계, 이미지 1/2 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Fan: 9 단계, 이미지 2/2
    • Remove the fan's power cable by pulling carefully outward towards the fan.
  10. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 10 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 10 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 10 단계, 이미지 3/3
    • Remove the 5mm Phillips #00 screw.
    • Pull up on the black tab connected to the fan. This will pull it away from the cooling fins, allowing it to be removed.
    • Remove the fan from the laptop.
  11. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, USB Port Board: 11 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, USB Port Board: 11 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, USB Port Board: 11 단계, 이미지 3/3
    • Remove the three 5mm Phillips #0 screws from the USB port board.
    • Lift the USB port board out of the laptop.
  12. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 12 단계, 이미지 1/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 12 단계, 이미지 2/3 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: 12 단계, 이미지 3/3
    • Pull the data cable out of the USB port board.
결론
Dylan Michael Leonard
회원 가입일: 11/05/19
423 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S1-G1, Barthe Fall 2019 UMass Dartmouth, Team S1-G1, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 2개
Hi Dylan. I inherited an older G751JL-BSI7T28 Asus gaming laptop. Do you know if the internal graphics card was able to be replaced by anything other than the 2GB Geforce that is in it? I hate top put money in an older laptop but other than it doesnt have USB C or USB 3.1, it really isn’t that bad of a laptop for its age.
cpruitt1@carolina.rr.com
cpruitt1 - 답글
The laptop is very formidable for it’s age but unfortunately the laptop’s GPU is integrated into the motherboard, so it cannot be swapped out. Hope this helps!
Dylan Michael Leonard - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 270
