주요 콘텐츠로 건너뛰기
Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement
필요한 것
  1. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: 1 단계, 이미지 1/2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: 1 단계, 이미지 2/2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 2 단계, 이미지 1/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 2 단계, 이미지 2/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 2 단계, 이미지 3/3
    • Use the standard spudger to remove the back center panel.
  3. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 3 단계, 이미지 1/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 3 단계, 이미지 2/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 3 단계, 이미지 3/3
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 4 단계, 이미지 1/2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 4 단계, 이미지 2/2
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 5 단계, 이미지 1/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 5 단계, 이미지 2/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 5 단계, 이미지 3/3
    • Remove the screws holding the hard drives in place using a Phillips 1 screwdriver.
    • Using the small flaps, remove the hard drives by hand.
  6. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 6 단계, 이미지 1/2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  7. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 7 단계, 이미지 1/2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 7 단계, 이미지 2/2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  8. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 8 단계, 이미지 1/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 8 단계, 이미지 2/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 8 단계, 이미지 3/3
    • Use a metal spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  9. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 9 단계, 이미지 1/1
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
  10. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 10 단계, 이미지 1/1
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
  11. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 11 단계, 이미지 1/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 11 단계, 이미지 2/3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 11 단계, 이미지 3/3
    • Use a metal spudger to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  12. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 12 단계, 이미지 1/2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 12 단계, 이미지 2/2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  13. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 13 단계, 이미지 1/2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 13 단계, 이미지 2/2
    • Use a pair of tweezers to undo each of the two ribbon connectors.
    • The Left and right button is now completely disconnected from the laptop and you can remove it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
D'Artagnan Scott Engle
회원 가입일: 04/01/19
297 평판
안내서 1개 작성함
IUPUI, Team S8-G8, Wilson Spring 2019 IUPUI, Team S8-G8, Wilson Spring 2019 회원
IUPUI-WILSON-S19S8G8
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 21
전체 시간: 1,118
