주요 콘텐츠로 건너뛰기
Asus ROG G751JT-DH72 RAM Replacement
필요한 것
  1. Asus ROG G751JT-DH72 RAM Replacement, RAM: 1 단계, 이미지 1/2 Asus ROG G751JT-DH72 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Lift up the rubber tab located in the upper-right corner of the backing plate.
  2. Asus ROG G751JT-DH72 RAM Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
  3. Asus ROG G751JT-DH72 RAM Replacement: 3 단계, 이미지 1/1
    • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
  4. Asus ROG G751JT-DH72 RAM Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the 5mm screw on the right side.
  5. Asus ROG G751JT-DH72 RAM Replacement: 5 단계, 이미지 1/1
    • Pull out the optical drive to revel the screws holding the laptop cover.
  6. Asus ROG G751JT-DH72 RAM Replacement: 6 단계, 이미지 1/2 Asus ROG G751JT-DH72 RAM Replacement: 6 단계, 이미지 2/2
    • Remove all 10 5.2mm Phillips screws holding the main back cover using the Phillips #1 screwdriver.
  7. Asus ROG G751JT-DH72 RAM Replacement: 7 단계, 이미지 1/1
    • Remove the four 5.2mm screws directly behind the backing plate using the Phillips #1 screwdriver.
  8. Asus ROG G751JT-DH72 RAM Replacement: 8 단계, 이미지 1/1
    • Flip over the laptop and pry the 2 vent covers off.
  9. Asus ROG G751JT-DH72 RAM Replacement: 9 단계, 이미지 1/1
    • Remove the two 6.8mm Phillips screws directly below the vent covers using the Phillips #1 screwdriver.
  10. Asus ROG G751JT-DH72 RAM Replacement: 10 단계, 이미지 1/2 Asus ROG G751JT-DH72 RAM Replacement: 10 단계, 이미지 2/2
    • Pry along the edges of the keyboard to lift it up.
    • Be careful not to damage the ribbon connectors.
  11. Asus ROG G751JT-DH72 RAM Replacement: 11 단계, 이미지 1/2 Asus ROG G751JT-DH72 RAM Replacement: 11 단계, 이미지 2/2
    • Disconnect all 4 ribbon connectors with a tweezer.
  12. Asus ROG G751JT-DH72 RAM Replacement: 12 단계, 이미지 1/1
    • Carefully, pull on the side tabs to release the RAM card.
결론
Anum Haidari
회원 가입일: 10/22/18
558 평판
안내서 3개 작성하였습니다
UC Davis, Team S7-G4, Lore Fall 2018 UC Davis, Team S7-G4, Lore Fall 2018 회원
UCD-LORE-F18S7G4
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 28
전체 시간: 1,127
