주요 콘텐츠로 건너뛰기
Asus ROG GL551J Battery Replacement
  1. Asus ROG GL551J Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Battery Replacement: 2 단계, 이미지 1/1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Battery Replacement: 3 단계, 이미지 1/1
    • Pull the battery out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jason Nguyen
회원 가입일: 02/20/17
356 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-4, Lacy Spring 2017 USF Tampa, Team 5-4, Lacy Spring 2017 회원
USFT-LACY-S17S5G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I need a guide to replace the MOTHERBOARD!! Do you guys have one of those? If not, do you have one that shows replacing the CMOS battery?
PLEASE HELP!!! I love this laptop and it’s only 4 years old and it’s DEAD!!!
Thank you,
Jana
hockeyblades - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,924
