주요 콘텐츠로 건너뛰기
Asus ROG GL551J RAM Replacement
필요한 것
  1. Asus ROG GL551J RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J RAM Replacement: 2 단계, 이미지 1/1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J RAM Replacement: 3 단계, 이미지 1/1
    • Pull the battery out.
  4. Asus ROG GL551J RAM Replacement, RAM: 4 단계, 이미지 1/2 Asus ROG GL551J RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Remove the two screws securing the access panel to the laptop.
  5. Asus ROG GL551J RAM Replacement: 5 단계, 이미지 1/2 Asus ROG GL551J RAM Replacement: 5 단계, 이미지 2/2
    • Slide access panel out and remove.
  6. Asus ROG GL551J RAM Replacement: 6 단계, 이미지 1/2 Asus ROG GL551J RAM Replacement: 6 단계, 이미지 2/2
    • Place thumbs on the locking tabs of both sides of the RAM stick and push outwards to unlock.
  7. Asus ROG GL551J RAM Replacement: 7 단계, 이미지 1/1
    • RAM should pop up at about 45 degrees. Pull outwards with fingers on the side of the RAM to remove.
결론
Congratulations, you now know how to replace the RAM sticks for your Asus ROG GL551J laptop, and this process can also apply to other similar laptops that you may acquire in the future.
다른 3명이 해당 안내서를 완성하였습니다.
Jason Nguyen
회원 가입일: 02/20/17
356 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-4, Lacy Spring 2017 USF Tampa, Team 5-4, Lacy Spring 2017 회원
USFT-LACY-S17S5G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 1,446
