주요 콘텐츠로 건너뛰기
Asus ROG GL551J Screen Replacement
필요한 것
  1. Asus ROG GL551J Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Screen Replacement: 2 단계, 이미지 1/1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Screen Replacement: 3 단계, 이미지 1/1
    • Pull the battery out.
  4. Asus ROG GL551J Screen Replacement, Screen: 4 단계, 이미지 1/2 Asus ROG GL551J Screen Replacement, Screen: 4 단계, 이미지 2/2
    • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
  5. Asus ROG GL551J Screen Replacement: 5 단계, 이미지 1/2 Asus ROG GL551J Screen Replacement: 5 단계, 이미지 2/2
    • Remove the middle screws located on either side of the display.
  6. Asus ROG GL551J Screen Replacement: 6 단계, 이미지 1/2 Asus ROG GL551J Screen Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
    • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
  7. Asus ROG GL551J Screen Replacement: 7 단계, 이미지 1/1
    • Remove the screws at each corner of the display.
  8. Asus ROG GL551J Screen Replacement: 8 단계, 이미지 1/2 Asus ROG GL551J Screen Replacement: 8 단계, 이미지 2/2
    • Remove the connector from the display by pulling the wire downwards.
    • Be sure to take note of the orientation of the connector when unplugging and plugging in.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Thien Vu
회원 가입일: 02/15/17
412 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-4, Lacy Spring 2017 USF Tampa, Team 5-4, Lacy Spring 2017 회원
USFT-LACY-S17S5G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 3,039
