주요 콘텐츠로 건너뛰기
Asus ROG Strix GL553VD Battery Replacement
필요한 것
  1. Asus ROG Strix GL553VD Battery Replacement, Battery: 1 단계, 이미지 1/2 Asus ROG Strix GL553VD Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Use a JIS screwdriver to remove the ten 4 mm screws from the bottom cover.
  2. Asus ROG Strix GL553VD Battery Replacement: 2 단계, 이미지 1/2 Asus ROG Strix GL553VD Battery Replacement: 2 단계, 이미지 2/2
    • Open the flap in the middle to reveal the 11th screw and remove it using the same JIS screwdriver.
  3. Asus ROG Strix GL553VD Battery Replacement: 3 단계, 이미지 1/3 Asus ROG Strix GL553VD Battery Replacement: 3 단계, 이미지 2/3 Asus ROG Strix GL553VD Battery Replacement: 3 단계, 이미지 3/3
    • Gently lift each corner to remove the cover from the laptop.
    • If you seem to have difficulty removing the cover, you may use a plastic opening tool to pry up one of the corners to get you started.
  4. Asus ROG Strix GL553VD Battery Replacement: 4 단계, 이미지 1/3 Asus ROG Strix GL553VD Battery Replacement: 4 단계, 이미지 2/3 Asus ROG Strix GL553VD Battery Replacement: 4 단계, 이미지 3/3
    • Gently pull the white battery connector out towards the battery.
  5. Asus ROG Strix GL553VD Battery Replacement: 5 단계, 이미지 1/1
    • Carefully lift the battery out from the case to remove it.
    • The battery will come off easily as the screws are already removed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Mahmoud Mehdi
회원 가입일: 09/20/20
247 평판
안내서 1개 작성함
York University, Team S1-G89, Woodhouse Fall 2020 York University, Team S1-G89, Woodhouse Fall 2020 회원
YORK-WOODHOUSE-F20S1G89
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Thank you for the guide. It was tricky to find the screw in the middle, hidden behind the flap. The screws are however not torx as shown.
Soheil Roshanbin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 67
전체 시간: 4,600
