소개
This guide explains how to remove the fans of the Asus ROG Strix GL702VM-BHI7N09 for replacement. Any of the three fans in the laptop can be replaced following these instructions.
필요한 것
Flip the laptop over to the back panel, with the serial numbers facing up.
Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
Once you have broken all the seals, carefully lift the panel off.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 8개
one of my laptop fans doesn’t work. where can i get a new one? I didn’t see any new fans for this model of laptop for sale anywhere
محمد رضا جان شما میتونید فن رو باز کنید و مشابهش رو از بازار تهیه کنید
I was wondering the same. I couldn’t find fans anywhere and after contacting ASUS about them they seemed less than interested in selling me the fans so that I could fix my laptop myself.
I got mine from ebay
