주요 콘텐츠로 건너뛰기
Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement
필요한 것
  1. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/2 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: 2 단계, 이미지 1/3 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: 2 단계, 이미지 2/3 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: 2 단계, 이미지 3/3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  4. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Zach Langer
회원 가입일: 04/10/17
676 평판
안내서 4개 작성하였습니다
Cal Poly, Team S13-G2, Forte Spring 2017 Cal Poly, Team S13-G2, Forte Spring 2017 회원
CPSU-FORTE-S17S13G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 7,054
