소개
Should the trackpad in your Asus ROG Strix GL702VM-BHI7N09 gaming laptop fail, this replacement guide is just for you! The trackpad is required for navigation and use of the computer.
Note that although this guide has you remove the motherboard and display before removing the trackpad, this is not absolutely necessary to replace the trackpad. Instead you can disconnect the cables as shown in Step 14 to remove the trackpad with the rest of the computer still intact.
필요한 것
Flip the laptop over to the back panel, with the serial numbers facing up.
Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
Once you have broken all the seals, carefully lift the panel off.
Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
Disconnect the speakers connectors located in each of the bottom corners.
Gently pull the wire up from the motherboard.
Once the wire is disconnected, pull the speaker out.
Ensure the ribbon cables on the trackpad are disconnected.
Using a Phillips #1 screwdriver, remove the three 4mm retaining screws.
Gently lift and slide the track pad out of the mount.
다른 한 분이 해당 안내서를 완성하였습니다.
