주요 콘텐츠로 건너뛰기
Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement
필요한 것
  1. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: 1 단계, 이미지 1/2 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 2 단계, 이미지 1/3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 2 단계, 이미지 2/3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 2 단계, 이미지 3/3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Battery: 3 단계, 이미지 1/1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 4 단계, 이미지 1/3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 4 단계, 이미지 2/3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 4 단계, 이미지 3/3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: 5 단계, 이미지 1/3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: 5 단계, 이미지 2/3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: 5 단계, 이미지 3/3
    • Using the iFixit Opening Tool, disconnect the black and white coaxial cables from the wifi card.
    • Using a Phillips #1 screwdriver, remove the 4mm retaining screw.
    • Gently slide the wifi card out from the connection slot.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 49
전체 시간: 2,342
