이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the laptop over to the back panel, with the serial numbers facing up.
Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
Once you have broken all the seals, carefully lift the panel off.
Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
Lift battery from laptop frame.
Using the iFixit Opening Tool, disconnect the black and white coaxial cables from the wifi card.
Using a Phillips #1 screwdriver, remove the 4mm retaining screw.
Gently slide the wifi card out from the connection slot.
