주요 콘텐츠로 건너뛰기
Asus ROG Strix GL702VS Trackpad Replacement
필요한 것
  1. Asus ROG Strix GL702VS Trackpad Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Trackpad Replacement: 2 단계, 이미지 1/1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Trackpad Replacement: 3 단계, 이미지 1/2 Asus ROG Strix GL702VS Trackpad Replacement: 3 단계, 이미지 2/2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Trackpad Replacement: 4 단계, 이미지 1/1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: 5 단계, 이미지 1/3 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: 5 단계, 이미지 2/3 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: 5 단계, 이미지 3/3
    • Disconnect the ribbon cables from the connectors at the bottom of the motherboard by lifting up the tabs with a nylon spudger tool.
    • Slide the ribbon cables out of the connectors on the motherboard.
  6. Asus ROG Strix GL702VS Trackpad Replacement: 6 단계, 이미지 1/2 Asus ROG Strix GL702VS Trackpad Replacement: 6 단계, 이미지 2/2
    • Remove the covering foil holding the trackpad into place.
    • Completely peel the foil back to ensure it does not interfere with the following processes.
  7. Asus ROG Strix GL702VS Trackpad Replacement: 7 단계, 이미지 1/2 Asus ROG Strix GL702VS Trackpad Replacement: 7 단계, 이미지 2/2
    • Lift up speaker cable that is laying overtop using a pair of tweezers.
    • Do not to overextend the wire since you may accidently pull the wire out.
  8. Asus ROG Strix GL702VS Trackpad Replacement: 8 단계, 이미지 1/3 Asus ROG Strix GL702VS Trackpad Replacement: 8 단계, 이미지 2/3 Asus ROG Strix GL702VS Trackpad Replacement: 8 단계, 이미지 3/3
    • Remove the three 4mm JIS #0 screws that are securing the trackpad.
  9. Asus ROG Strix GL702VS Trackpad Replacement: 9 단계, 이미지 1/2 Asus ROG Strix GL702VS Trackpad Replacement: 9 단계, 이미지 2/2
    • Once freed, slide the trackpad backwards towards the center of laptop.
    • This may require some jiggling. Lifting the laptop off your working surface may help.
    • Sliding the trackpad back in can be a bit tricky. Ensure it is fully seated before continuing reassembly.
결론
Conor H Allen
회원 가입일: 09/16/19
622 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 802
