주요 콘텐츠로 건너뛰기
Asus ROG Strix GL702VS Webcam Replacement
필요한 것
  1. Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): 1 단계, 이미지 1/3 Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): 1 단계, 이미지 2/3 Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): 1 단계, 이미지 3/3
    • Remove the two screw stickers at the bottom corners of the screen.
    • Remove the two 4mm JIS #0 screws beneath the stickers.
  2. Asus ROG Strix GL702VS Webcam Replacement: 2 단계, 이미지 1/3 Asus ROG Strix GL702VS Webcam Replacement: 2 단계, 이미지 2/3 Asus ROG Strix GL702VS Webcam Replacement: 2 단계, 이미지 3/3
    • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
    • Using an opening tool, lift up the bezel once the glue has been removed.
    • The plastic clips remain so it will have some resistance/snapping noises.
  3. Asus ROG Strix GL702VS Webcam Replacement: 3 단계, 이미지 1/2 Asus ROG Strix GL702VS Webcam Replacement: 3 단계, 이미지 2/2
    • Lift the plastic bezel off of the front display panel.
    • The plastic bezel will click when put back on the screen.
  4. Asus ROG Strix GL702VS Webcam Replacement: 4 단계, 이미지 1/1
    • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
  5. Asus ROG Strix GL702VS Webcam Replacement: 5 단계, 이미지 1/3 Asus ROG Strix GL702VS Webcam Replacement: 5 단계, 이미지 2/3 Asus ROG Strix GL702VS Webcam Replacement: 5 단계, 이미지 3/3
    • Once the LCD display is freed you can lift it up out of the casing.
    • Be careful as the cable remains attached.
  6. Asus ROG Strix GL702VS Webcam Replacement: 6 단계, 이미지 1/2 Asus ROG Strix GL702VS Webcam Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
    • Once fully disconnected, remove the LCD and replace it.
  7. Asus ROG Strix GL702VS Webcam Replacement, Webcam: 7 단계, 이미지 1/1
    • Gently lift the webcam out of its resting position at the top of the LCD assembly.
  8. Asus ROG Strix GL702VS Webcam Replacement: 8 단계, 이미지 1/2 Asus ROG Strix GL702VS Webcam Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the nylon tweezers or your hand, disconnect the webcam module.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexander M. Lanyi
회원 가입일: 09/16/19
125 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 534
