소개
This is a step by step process for the replacement or repair of the webcam on your Asus ROG Strix GL702VS laptop. If you are experiencing bad quality or a black screen while using the webcam, follow these steps to remove the webcam and replace it.
필요한 것
Remove the two screw stickers at the bottom corners of the screen.
Remove the two 4mm JIS #0 screws beneath the stickers.
다른 한 분이 해당 안내서를 완성하였습니다.
