주요 콘텐츠로 건너뛰기
Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement
필요한 것
  1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: 1 단계, 이미지 1/2 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: 1 단계, 이미지 2/2
    • Remove the front panel.
    • This may involve one or two thumb screws depending on your case.
  2. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 2 단계, 이미지 1/1
    • Detach the PSU cable from your graphics card.
  3. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 3 단계, 이미지 1/3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 3 단계, 이미지 2/3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 3 단계, 이미지 3/3
    • Unscrew the back panel screws to release the graphics card.
    • Release the PCIe switch.
    • Be careful when using a tool as you can damage the motherboard if the tool slips.
    • Take the graphics card out vertically.
  4. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 4 단계, 이미지 1/3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 4 단계, 이미지 2/3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 4 단계, 이미지 3/3
    • Unscrew the heat-sink screws.
    • Remove the heat-sink vertically.
    • It is important to remove it vertically as there are pins on the right side that must not be bent.
  5. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 5 단계, 이미지 1/3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 5 단계, 이미지 2/3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: 5 단계, 이미지 3/3
    • Unscrew the small screw holding the SSD.
    • Remove the SSD at an angle.
    • Be careful to avoid grabbing the SSD from its circuit.
    • Insert a new SSD at a 30-40 degree angle.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Christian Clark
회원 가입일: 02/22/22
205 평판
안내서 1개 작성함
University of North Texas, Team 1-7, Raign Spring 2022 University of North Texas, Team 1-7, Raign Spring 2022 회원
UNT-RAIGN-S22S1G7
2 회원들
안내서 1개 작성하였습니다
댓글 2개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 67
전체 시간: 3,742
