주요 콘텐츠로 건너뛰기
Asus ROG ZX50VW-BH17N10 Hard Drive Replacement
필요한 것
  1. Asus ROG ZX50VW-BH17N10 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Remove the 16 mm and 9 mm screws on the small panel on the bottom of the laptop using the Phillips #1 screwdriver.
  2. Asus ROG ZX50VW-BH17N10 Hard Drive Replacement: 2 단계, 이미지 1/3 Asus ROG ZX50VW-BH17N10 Hard Drive Replacement: 2 단계, 이미지 2/3 Asus ROG ZX50VW-BH17N10 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Insert the metal spudger into the lip of the back panel and gently pry it off.
  3. Asus ROG ZX50VW-BH17N10 Hard Drive Replacement: 3 단계, 이미지 1/2 Asus ROG ZX50VW-BH17N10 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Unscrew the four 9 mm screws on each corner of the hard drive using the Phillips #1 screwdriver.
  4. Asus ROG ZX50VW-BH17N10 Hard Drive Replacement: 4 단계, 이미지 1/2 Asus ROG ZX50VW-BH17N10 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Pull the black film tab towards the outside of the computer to unplug it.
    • Remove the hard drive by pulling up on the black film tab.
결론
Naomi Rodriguez
회원 가입일: 09/17/19
747 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 7
전체 시간: 316
